Horns not working - NCRS Discussion Boards
Horns not working
  • Bill M.
    • 1328
    Horns not working
    the horns on my 66 were not working. checked both with an external source. there is a new wiring harness fuse good ground looks good replaced relay. Bingo can wake up the neighborhood. Go for 1/2 hour ride horns not working again. Is it maybe the button inside the steering hub?Bill
  • Roger G.
    • February 28, 2011
    • 92
    Re: Horns not working
    Do the horns work consistently when you apply external power?
    If so, do they work immediately after plugging them back into the wiring harness, then stop working after sitting for a while?
    I'm wondering if the contacts, internal to the horn, may be corroded.
    I ended up having to replace my horns, they sat too long, corroded. One worked intermittently, the other not at all.
    Another option may be to check for power reaching the horn. Do you have a volt meter or test light?
    Connect a meter or test light to the harness, press the horn button, see if you're getting 12V to the connector.
    • Bill M.
      • 1328
      Roger yes I have a meter I will check. the horns rang as long as the 12v was applied. thanks
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 927
        Bill, the horn relay get's it's ground from the steering column center shaft. Check the shaft with your meter and see if it has a constant ground. There is a brass or copper strap inside the steering coupler that transfers the ground from the steering box to the column. This strap wears out as the coupler ages. Good Luck, Joe
          • 6955
          To add to Joe's response go out to the horn relay and listen for a click when someone pushes the horn button. this will let you know if the is power and if the ground is good to relay. with this simple inspection. sometime the relay points will fail not permitting power to go to horns.and another is the ground on radiator support can be an issue if there is not a bare metal finish and also a star washer between the ground wire and support.
          • Jim T.
            • March 1, 1993
            • 5351
            I do not have a C2 any more, however when the horn would not work on my 1985 I found out why. Removing the steering wheel cap it was easy to see why, a plastic connector had broken. Can't describe it exactly since it was many years ago, but it was a easy fix without having to buy any parts, had something in the garage to fix it.
            • William F.
              • June 9, 2009
              • 1364
              Common things common. Take relay off; take apart and lightly dress the points to remove corrosion.
              • Bill M.
                • 1328
                thanks all will do this weekend I ordered a new horn contact just in case. the relay is a pircle rebuild but has ben sitting for years will check that as well.
