63 Wonder bar search function - NCRS Discussion Boards
    • 6955
    Have any of you taken apart your wonder bar radio to fix the search function, as mine has stop working? I can hear a static click when button is pressed. and was moving normally. Maybe some sort of contact needs cleaning?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11361
    Re: 63 Wonder bar search function
    Edward, I fixed the scan on my '59 about 20 years ago. Yup, it was a dirty contact on the internal switch.
    I's imagine '63 has a similar contactor, not sure. But if all else fails give member Jerry Rudbeck a jingle.
    Rich
      • 6955
      Rich, Thanks for your reply, I took the radio out yesterday and plan on taking apart to look and see if there maybe someting I can do, I will check the switch hopefully that is the issue.
      • Wayne M.
        • March 1, 1980
        • 6414
        Edward -- if you can get your hands on a 1963 Chevrolet Radio Service & Shop manual, it has 13 pages on the Corvette Wonderbar AM radio, model No. 985396, and in particular, the following sections on the signal-seek function:
        Mechanical operation of electrical tuner (overview); Theory of operation; Mechanical operation; Gear train operation; Relay arm; Solenoid; clutch, etc. Also, service procedure of all parts, including (R & R relay, relay gear train, solenoid switch, solenoid, .... Service parts list).
        • Troy P.
          • February 1, 1989
          • 1284
          I have an early 63 that came with the AM radio as FM was not offered early in the model year. When I lived in San Diego all I could get was stations from Mexico so I replaced it with a later AM/FM. No wonderbar on that one. I have my original radio packed away. I don't recall it having a wonderbar but I haven't seen it n many years. Is the AM radio signal seeking?
            Troy -
            Yes, the AM radio is signal-seeking.
              • 6955
              Edward, I fixed the scan on my '59 about 20 years ago. Yup, it was a dirty contact on the internal switch.I's imagine '63 has a similar contactor, not sure. But if all else fails give member Jerry Rudbeck a jingle.Rich
              Rich it took a couple attempts to repair, But just wanted to let you know you were correct. The wonder bar switch contacts were dirty I cleaned them, and its back t working. thanks.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11361
                Nice ! Glad you got it.
