67 Side Pipe hardware - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2009
    When I took my 67 apart many years ago, I believe the pictured part was used to attach the side pipe muffler to the car frame. Is this a correct Corvette part or are the side pipes just supported by carriage bolts at the frame?
  • Scott M.
    • January 1, 1996
    • 216
    Re: 67 Side Pipe hardware
    That looks like a Hooker Header side mount "T" bolt. I believe carriage bolts are correct.
    • Leif A.
      • August 31, 1997
      • 3650
      Not sure what you have there but it is NOT used to attach the side exhaust to the car frame. The bolt should be round with a squared off area directly below the bolt head to lock in the key way. See pics for the assembly.
      Leif
      • Patrick B.
        • August 31, 1985
        • 2009
        Thanks Scott and Lief, I'll order the Paragon hardware kit.
        • Leif A.
          • August 31, 1997
          • 3650
          Their's should work just fine.
          Leif
