A Corvette Video - NCRS Discussion Boards
A Corvette Video
  • Joe C.
    • August 31, 1999
    • 4598
    A Corvette Video
  • Pat M.
    • April 1, 2006
    • 1578
    Re: A Corvette Video
    Damn that sounds sweet ... Release the Kraken!
    • Dan A.
      • May 31, 1974
      • 1074
      How many RPM did you bring it up to?
      • Joe R.
        • May 31, 2006
        • 1822
        Don't tease us like that, Joe. We want to see your dyno results!
        Joe
        • William F.
          • June 9, 2009
          • 1364
          What's with the exhaust smoke? Oil problem? too rich? just condensation?
          • Joe C.
            • August 31, 1999
            • 4598
            Originally posted by daniel adie (60)
            how many rpm did you bring it up to?
            7500 rpm ...
            • Joe C.
              • August 31, 1999
              • 4598
              I used low tension oil scrapers on the build.
              • Rocco C.
                Infrequent User
                • January 8, 2014
                • 25
                Very nice. Im sure you would give a BB a good run for its $$
                • Mike E.
                  • June 24, 2012
                  • 920
                  Joe
                  +1
                  Mike
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    More like blow the BB away. Remember it it takes a dam good running BB to beat a built Small Block.
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      Here are the dynoruns:
                      http://
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11325
                        Wow, very impressive Joe, and it looks awesome too.
                        When you hit 7500 I bet a little pee came out.
                        • William F.
                          • June 9, 2009
                          • 1364
                          Share your build specs, "secrets", if you will!
                          • Walter F.
                            • October 22, 2006
                            • 373
                            Can some one explain this statement. More horsepower and cubies on the BB. Wasnt that the reason it was designed to be faster?
                            • Joe C.
                              • August 31, 1999
                              • 4598
                              Thanks William.
                              Major precepts to a superb engine build:
                              1. Make your DCR close to 8.5:1 if you plan on using high test 93 PON pump gas, which means that SCR must be matched to intake valve opening, stroke, and rod length. You may go as high as 8.75:1, but you will be on the ragged edge of detonation, and your build MUST be within very tight tolerances!
                              2. Engine must employ latest cam technology, which means a hydraulic roller. If you want a build more like mine, then a solid roller should be used.
                              3. Headers essential, but undercar tuned headers will optimize. (True if run open after the collectors).
                              4. Tight quench is essential.
                              5. Careful detail and close tolerances must be employed.
                              6. Have your spark advance come in ASAP, so long as WOT does not exceed 34-38 degrees BTDC. This could very well mean a 20+ degree initial setting, without vac advance connected.
                              7. Carefully ported double hump heads with 2.02/1.60 valves can yield as much as about 360 RWHP! The heads used in this build are quite a bit larger.
                              8. Crower Sportsman rods were used, as was a small journal 327 block with 2 bolt mains. Stock caps with bolts (no cap studs) were used.
                              This is not the right place to discuss "modified" Corvettes, but I can tell you that only the more savvy Corvette experts can detect that this engine has been modified except for the headers. There are a lot of secrets that I learned over the years, and which I won't divulge here.
                              Be careful whose advice you take on this website. Most here are too stuck in the past to attempt anything like I have done.
                              It's fun to blow away all C5 Corvettes, including Z06s, as well as stock LS3 C6s, and almost stay up with Z06 C6's as well. All this while getting over 23 mpg @ 75 MPH in 5th.
