Ballast Resistor - NCRS Discussion Boards
Ballast Resistor
+ More Options
Posts
  • Harold R.
    Infrequent User
    • December 20, 2010
    • 26
    Ballast Resistor
    Does anyone have a good picture of an original ballast resistor for a 57' (December 56 build date)?
    Re: Ballast Resistor
    Harold -
    I have this photo ID'd as "56-'57, no trough"; if it's not correct, I'm sure someone will chime in.
    • David S.
      • December 1, 1982
      • 310
      Harold I have attached a picture from car # 4713 built about June 20, 1957
      Let me know if this gives you any help.
      Dave
      • Mike M.
        • May 31, 1974
        • 8400
        note the "thumbnail" and the tab on the bracket. dave's pic doesn't show a side view of the porcelain but it should not have a shallow cut out on each end like the c-2's. mike
        • David S.
          • December 1, 1982
          • 310
          Another picture that is not great but it does show no notch on the end as Mike says
