gas cap clean up - NCRS Discussion Boards
gas cap clean up
  • Don W.
    • September 30, 1997
    • 492
    gas cap clean up
    My '69 gas cap is oxidized with white stains and discoloration; I want to know how best to clean it up. Is it aluminum and should I use aluminum polish or is it built with a different metal? Also, once cleaned up, what's the best method to limit future staining; auto wax? thanks...Don
    • 43219
    Re: gas cap clean up
    Don------
    The cap is NOT aluminum. It's mostly steel and zinc plated. Over time, the zinc finish oxidizes and loses all of its luster and become dull. Most chemicals that you could use to clean it up could damage or, even, remove the zinc plating.
    • Don W.
      • 492
      Thanks Joe, I may have already ruined it years ago by trying clean it up with polish...Don
      • Gary H.
        • June 30, 1980
        • 155
        Soak it in full strength Simple Green overnight rinse it off. Repeat as necessary!
        • Bruce B.
          • May 31, 1996
          • 2930
          Go to a hobby store and get a tube of silver "Rub & Buff".
          Rub it on the cap and then buff it with a soft cloth it will look great.
          • Ara G.
            • January 31, 2008
            • 1108
            0000 steel wool at Home Depot. Works amazingly well on radiator caps with the oxidation as well. I tried it on a junk cap first and wow.
            • Russ S.
              • April 30, 1982
              • 2162
              Or have it re-plated. It should be white cadmium. (silver)
              • Mike F.
                • April 25, 2011
                • 668
                I soaked mine in Evaporust for a day. Removed all of the oxidation, but left the patina. I can post a pic tonight.
                • Lawrence S.
                  • April 1, 1993
                  • 801
                  X2 with Evap o Rust
                  • Floyd B.
                    • November 1, 2002
                    • 1046
                    Just beware that products like evapo-rust will remove ALL sacrificial coatings. Remember that rust/oxidation is itself is a form sacrificial coating.
                    "Drive it like you stole it"
                    • Jerry K.
                      • December 1, 1981
                      • 93
                      I love Rub & Buff silver, also comes in gold and black. Used it on my 62 Duntov in many cad plated parts. Clean first with Simple Green and remember a little R&B goes along way. purchased it at Michaels Crafts in Flint Michigan
                      • John D.
                        • December 1, 1979
                        • 5507
                        I agree with what Russ suggested. Easy and original looking. Just have the cap cadmium plated.
                        But don't try to have most radiator caps cad plated. Some have an aluminum rivet holding them together. Cad plating process will melt the aluminum. JD
