3x2 jetting - NCRS Discussion Boards
3x2 jetting
  • Robert D.
    • April 1, 2003
    • 305
    3x2 jetting
    What jets are you guys using in your middle carb in a 3x2 setup. my car has 63 in it and it seems to be running very lean it a 435 hp car thanxbob
    Re: 3x2 jetting
    Bob -
    #64 jets are specified for the center carb on a 427/435hp car.
    • Ken A.
      • July 31, 1986
      • 929
      Re: 3x2 jetting
      Unless you in a high altitude, 66's run better.
      • Mike T.
        • January 1, 1992
        • 568
        Re: 3x2 jetting
        Robert - Are you noticing some 'surging' when you're driving, plugs a bit too white?
        Mike T. - Prescott AZ.
        • Robert D.
          • April 1, 2003
          • 305
          Re: 3x2 jetting
          Micheal thats exactly whats happening thanx guys
          • Timothy B.
            • April 30, 1983
            • 5188
            Re: 3x2 jetting
            Make sure you are working on the right circuit. If the surge is at 2500 +- the carburetor is still on the idle circuit. If the surge is at 300+ RPM then it's the main circuit. The idle feed restriction can be opened just a bit to correct this condition.
