Archive Search Engine Test *TL* - NCRS Discussion Boards
  • John W.
    Administrator
    • November 1, 1974
    • 5087
    All,
    I have put together a new Archive Search Engine. https://www.ncrs.org/forum/archivesearch.htm It is just a little different format than the Tech Board and the current Archive Search. It does search a little over 79,000 messages at the same time. There are currently over 100,000 messages in the Archives, but even this script times out before it can search over the 80,000 number.
    Try it out and let me know what you think. Is it and improvement?
    John Waggoner
    Administrator
    www.ncrs.org
  • Richard S.
    • November 1, 1994
    • 809
    Re: Archive Search Engine Test
    John,the new format is great. I just tried it for "1967 Tank Sticker" and received over 100 messages filled with useful information. Thanks very much for making the "SEARCH" feature much more user friendly.
    • Dick C.
      Past NCRS President
      • November 1, 1995
      • 453
      John, Works great, thanks for updating the system. Good job as always. Dick
      Dick Capello
      New England Chapter/Mid Atlantic Chapter
      Past NCRS President
      Past Region 1 Director
      • Juliet P.
        • June 30, 1999
        • 349
        Well, I just tried it and received the following error. I'm on dialup, currently connected at 42k. ~Juliet
        Error 500: Internal Server Error
        Your request could not be processed due to an internal server error. The server was probably busy handling other requests. Use your back button and retry your request. If you were making an order rest assured that you will not be double billed if there was a server error.
        2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
        1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
        1965 Coupe (Greg's project No Flight)
        Gone but not forgotten:
        1987 Yellow Convertible 199k mi.
        2002 Yellow Convertible 100k mi.
        2007 Atomic Orange Coupe 140k mi. RIP flood 2015
        2007 Lemans Blue 6-Spd Coupe 34k mi.
        • Larry P.
          • June 30, 1999
          • 481
          Great! Now if we all use a year or model..YEA
          John,
          This works great. I have DSL and it still takes a little time, but it
          works great. Thanks
          Larry
          • John W.
            Administrator
            • November 1, 1974
            • 5087
            Re: Archive Search Engine Test *TL*
            Juliet,
            That is the error that comes up when the server times out before the search is complete. I don't think it matters if you have dial up, or cable access it is a function of the servers speed. If I tried to include more than the 79,000 messages that are included I got that message every time. If it is going to be common I may have to back off to about 70,000 messages or even less. This then leaves about 30,000 unsearched messages, or I need to create a second search for those messages. Maybe two searches of about 50,000 messages each instead of the 11 groups that are now in service.
            We are generating about 36,000 messages a year at our current rate, so we will soon be back in the same boat.
            John
            Administrator
            www.ncrs.org
            • Nick Culkowski
              Greatly needed improvement! I did get the error message, but after modifying the search description I was able to read many archived & relevant posts. Maybe we chould be more specific (methodic) in an organized way when originally posting to assist future searches?
              • Richard S.
                • November 1, 1994
                • 809
                John, as I said yesterday,using "1967 Tank Sticker" I received 150 messages. I only had time to read 50 to 60 yesterday. Today, using the same, and I mean exact parameters, it will only pull up 40 messages. What happened? Thanks for your help.
                • John W.
                  Administrator
                  • November 1, 1974
                  • 5087
                  Rick,
                  I am not sure what to tell you. I tried to duplicate your results today. When I searched on "1967 tank sticker" if I searched on "all terms" which means a message must contain 1967 + tank + sticker to meet the criteria I got about 40 matches. If I tried on "any terms" which means the message contains 1967 or tank or sticker, I got an error that the server was overloaded. I tired it a dozen times. I finally revamped the search script to only search about 44,000 messages before I could get a return. I then got "(44,062 files searched; 2,241 matches found)".
                  This may take some more tweaking to get it worked out so it is reliable.
                  John
                  Administrator
                  www.ncrs.org
                  • Mike E.
                    • February 28, 1975
                    • 5138
                    John--
                    Thanks for continuing to work at it!!!!!!!!
                    Mike Ernst #211
