C3:PN's for choke and EGR - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    Does anyone have part numbers for a 73 L48:
    Choke housing,spring, lever to choke
    EGR valve, gasket and the bracket that hold the valve in place
    TIA
    Steve L
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43236
    Re: C3:PN's for choke and EGR
    Steve----
    Choke thermostat------ GM #326079
    Thermostat cover-------GM #14006795
    rod--------------------GM #3998966
    EGR valve-----(4 speed)GM #7040318, SERVICE= GM #17051819 =DISCONTINUED
    THM-400)GM #7035172, SERVICE= GM #17051810
    Valve clamp-------------GM #353090
    valve gasket------------I don't think that 350 cid engines used a gasket
    • Steve L.
      • June 30, 2001
      • 763
      Once again, thanks for the numbers.
      No gasket on the EGR?- can't remember to '73. I remember it running the pits after it warmed up. From what I remember I could watch the EGR cutting in after it warmed up, and immediately it run rough. So I disconnected it and eventually took it out and replaced it with a brass plate.
      I recently saw someone on ebay selling a gasket claiming to come from a 73 base corvette engine with a NOS Gm part no in the original package GM 353086 and the "correct"color white??? So what was this gasket really for?
      (I'm really not impressed with all the "correct" claims on ebay - I sometimes check with the claims on my original and it's not the same at all)
      Steve L
      73 coupe since new
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Harmon C.
        • August 31, 1994
        • 3228
        EGR Has a white thick fiber gasket in 73 *NM*
        Lyle
          • 43236
          Steve-----
          The GM #353086 gasket was a thick, white gasket and it was used in 1973. However, I believe that this gasket was used only for 454 engine applications. It's possible that it was also used for 350s but I can find no record of its use for those applications
          • Steve L.
            • June 30, 2001
            • 763
            Joe,
            I think you might be right. I took that stuff off around '77 and replaced it with a machined brass plate that is still there. I put RTV under the plate. I would have replaced the gasket if it was there rather than the RTV. Since then the EGR valve got chucked. (Can't imagine what I was thinking in those days)
            Why would they put a gasket on a 454 and not on a 350? You'd think that you would need to seal properly between the casting and the sheet metal valve.
            Steve L
            73 coupe since new
            Steve L
            73 coupe since new
            Ottawa, Canada
              • 43236
              Steve-----
              I can't figure out why they would have used a gasket for the 454 EGR valve, but not for the 350. 1973 was the first year for EGR on Corvettes, though, and, perhaps, they just hadn't sorted everything out yet. Different design teams may have worked on the 454 EGR design than worked on the 350 EGR design.
              • Harmon C.
                • August 31, 1994
                • 3228
                Joe
                The EGR valves clamp on the same way on the 454 as the 350 and all my 73's have a thick gasket that is brown but may have been white and is asbestos like material. A 454 gasket would fit fine as the EGR and clamp are the same shape but different part number.
                Lyle
