C2 Carpet in general (RE: '63 Carpet) - NCRS Discussion Boards
  • David Roberson
    Let me start with a THANKSGIVING for all of you guys who have helped me with my restoration project. I am truely thankful that God has given me a network of guys (and gals!) who share my passion for Corvettes.
    That said,
    In reading the comments on the '63 Carpet post, I was wondering about the interior paint coverage UNDER the carpet. I know that this isnt judged, but I have decided to go on and restore the interior fiberglass surfaces as new.
    On my car, someone had glued some thick (1/2") foam rubber backing down directly to the fiberglass, then glued replacement carpet to the foam backing. I had to scrape, rub and scrub for weeks to get all of the foam rubber remnants up. Under this (non-original) foam rubber underlayment, it appears that the interior fiberglass was originally primed, then painted to match the interior color. My car is Tuxedo black with red interior. It looks like the entire floor had been painted (under the seats, jack storage area, rear storage area) with red paint on top of red/brown primer. But it is a little bit hard to tell for sure where the red paint ends and the red/brown primer begins.
    Id like to know what the coverage of primer and interior color paint was. Also, what was the 'order' of this paint (before/after exterior coat, before/after black paint on Z-bar etc., before/after seat belt reinforcements). Thanks for your help and happy Thanksgiving
    David Roberson
    You can see pics of what Im talking about at my website 1963Vette.com. This is NOT a commercial website (no advertisements etc.).
    1963Vette.com - documentary of a restoration
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 Carpet in general (RE: '63 Carpet)
    I carpeted my 63 convertable last winter. The old carpet was not the original but when I stripped it the fibergalss had no paint on it at all. I believe that is the way the car was built. The jack recess compartment was painted the interior color. The rest of the interior was clean. I took several photos of the restoration of my interior if you would like too see them let me know.
      • 15694
      The body was painted before the glass was installed and prior to ANY hardware being installed other than the doors which were open to give the painters access to the door jams.
      The result of this is a fairly even coat of mostly top coat overspray, which I did not remove.
