I just finished reading the post and responses of 9/09/02 about this very subject and yet I'm still having a challenge. When I place the heat riser to the forward side with the counterweight toward the engine, the counter weight hits the starter. I've checked with John Pirkle and he explained that I have a correct diameter on my starter. If I rotate the heat riser 120 degrees toward the passenger side pipe the counterweight hits on the inner fender. I can make it fit if I mount the heat riser to the rear but I need to loosen the starter to slide the heat riser past the top of the starter. I want the heat riser to both work and be mounted correct for NCRS judging. Thanks as always for the help. The part number on the counterweight 3746844
Barry Mills 35394
Barry Mills 35394
