Body shim question - NCRS Discussion Boards
Body shim question
  • Rob Dillard
    Body shim question
    On my Janurday 8th '68 built car I have some questions on the body shims.
    In all locations I have the alum. puck shim, all locations have what appears to be a steel shim/washer just slightly smaller than the alum puck. Some locations have a square thim plate/shim. My question is concerning the marked shim count. Which of the previous are counted as shims. ie. #4 is square plate, washer looking shim and a alum. puck. Is that shim count for that location 3? Thanks in advance.
    Rob
  • Rob Dillard
    Re: Body shim question
    ANY help would be appreciated. thanks
    Rob
    • Gene M.
      • April 1, 1985
      • 4232
      Rob, You must be talking about a C3 like a 68. The shims are only the square steel sheet metal pieces with the formed up corners. These are the only pieces counted for shims and markings.
      • Rob Dillard
        Gene,
        Thanks for the response. That makes sense all locations have one of each of the alum and steel blocks. At locations where no shims were needed was a zero marked?
        Rob
