'58 - Wires through firewall question - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    In my notes and drawings from inspecting other C1s, I wrote that through the hole where the wiper motor cable goes through, there is also a wire. I wrote "sensor wire." With my wiring harness (Lectric Limited), I don't see how the temp sender wire could make that stretch, so what is it? An owner mod, maybe?
    Also, in the firewall grommet set I bought, one grommet has two holes in it. Where does it go?
  • Mike G.
    • April 30, 2001
    • 180
    And which hole for oil pressure line?
    Could it be that I mislabeled "oil pressure line" as "wire sensor?"
    • Al C.
      • July 31, 1999
      • 274
      Re: And which hole for oil pressure line?
      Mike -
      I looked at mine, the oil gauge line is thru the same large grommet as the wiper actuator cable.
      ... AL '58 #378 245hp
      • Geoff C.
        • May 31, 1979
        • 1613
        2 hole grommet 4 w. washer hoses *NM*
        • Mike G.
          • April 30, 2001
          • 180
          Thanks guys! *NM*
