C2 L76 Water Pump Attaching Bolts - NCRS Discussion Boards
  • Scott Smith 38530
    Although I have the AIM, shop manual and many parts catalogs I have no exploded view showing the water pump attaching hardware. Am I correct in believing that there is a washer (not LOCK washer)on the front side of the alternator bracket and no other washers between the remaining bolt heads/idler adjustment stud and the water pump?
  • David Roberson
    Re: C2 L76 Water Pump Attaching Bolts
    Scott, I believe that this is correct. One washer in front of alt support arm - no other washers. Good Luck!
    David
    1963Vette.com - documentary of a restoration
