Carter AFB Rebuild Screw Up - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    Well, I think I really did it this time. In tearing down my series 9000
    Carter AFB, I tried to remove the "disks" from the rod that goes through the
    carb body (the disks that flip open and closed under the primaries and
    secondaries). They are held in place with 2 brass (?) screws each. The ones
    under the secondaries came out w/o a problem, permitting the removal of the
    rod from the body. disaster struck on the primary side - screw snapped off
    after coming out about two turns. Does anyone know a source for these screws,
    or for a replacement rod if I have to drill out the piece that's still in
    there?
    Thanks for any and all suggestions. I've never rebuilt a carburetor before
    and I am beginning to regret it.
    Mark
  • James F.
    • December 1, 1985
    • 596
    Re: Carter AFB Rebuild Screw Up
    Mark,
    You have mail. I'm not up to typing my post all out again ;-)!
    • Craig S.
      • June 30, 1997
      • 2471
      Jim - copy & paste works well, then we can all learn...Craig
      • James F.
        • December 1, 1985
        • 596
        • Brian Monticello
          Mark,
          I'm in the same boat as you but being addicted to EBAY as I am I bought a guinea pig Carter AFB to take the brunt of my rebuild "skills" before I attack my original. Its not a Corvette carb but is physically similar save the choke and hey, it was $35!
          My point: check EBAY - I've seen misc. Carter AFB parts - Includ ing the throttle plates, screws, and shaft as you describe. I haven't opened my test carb yet. Let me know how it goes and good luck!
          Brian
            You'll find...
            the Chicago Corvette catalog has probably the LARGEST selection of off-the-shelf parts for Carter WCFB and AFB carbs (probably a full 3-4 pages of NOTHING but individual Carter carb parts listed). Check 'em out....
