67 Rear Crossmember for Differential - NCRS Discussion Boards
  • Craig S.
    • June 30, 1997
    • 2471
    Well, I am finally getting around to preparing the parts of my 67 to reassemble the rear end in the car. I have the differential carrier, beaded, cleaned and coated with a light coat of krylon semi flat clear to keep the rust away. The crossmember with the rubber cushions that mount on the sombreros is ready to paint, I intend to use the rustoleum paint Joe Lucia mentioned before. I have new GM cushions to install. when the factory built this assembly, was the paint applied before or after the cushions are installed in the member? I would like to know if I should get paint on the rubber cushions or not in preparing the part for installation.....thx!...Craig
    Re: 67 Rear Crossmember for Differential
    Craig -
    If memory serves me correctly, the crossmember itself (welded assembly of several stampings) was dip-primed before the cushions were installed at Dana.
    • Craig S.
      • June 30, 1997
      • 2471
      Thx John! Now I know how to proceed!..I did see the Dana stamp mark on the top of the crossmember...Craig
