Horn mounting questions ('58) - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    My AIM is very washed out on this page (sec 12.7). Is the plate which mounts to the inner fender oriented with the rivets toward the outside and the welded nut to the inside of the car? Or is it rivets to rear and nut to front?
    And is that plate right to the edge of where the inner fender starts to curve and end (as we're headed toward the front emblem area)? How far up, about half way?
    Finally, is the high horn on the left? Note my car will never be flight judged, so please don't go to a lot of trouble crawling around and measuring. Just an eyeball estimate would be great! Mostly, I just want to make sure I'm not way out of whack. Thanks as always!
  • Al C.
    • July 31, 1999
    • 274
    Re: Horn mounting questions ('58)
    Hi Mike -
    I only just read your question, late Sunday - I have my car open to the horns and I will look in the morning - maybe email you some pix.
    ... Al '58 #378
    • Mike G.
      • April 30, 2001
      • 180
      Thanks Al, that would be great! *NM*
