'67 SB Timing Cover - NCRS Discussion Boards
'67 SB Timing Cover
  • Richard Pressley
    '67 SB Timing Cover
    What is the correct timing cover tab for '67 SB 327/350? Paragon lists two; tab 6736 and tab #1763.
    • 43221
    Re: '67 SB Timing Cover
    Richard-----
    The L-79 used an 8" OD balancer. The timing tab used with this balancer had the timing cover attaching surface on the tab go "DOWN". I think that this is the Paragon #1763 tab. Engines with the 6-1/2" balancer had a different timing tab with the timing cover attaching surface on the tab going "UP".
