72 wiper motor wire colors - NCRS Discussion Boards
  • David H.
    • December 1, 1996
    • 241
    Thank you much if anyone can list the exact colors; lbl,dbl,ext. of the wires and locations that connect to a 72 wiper motor, three vertical and two horizontal for the washer. David
  • george romano
    Re: 72 wiper motor wire colors
    I just checked my 72. The three prong plug under the body of the motor is on a slight angle. The wire colors are (starting from the bottom, or lowest wire):
    Green
    Yellow
    L Blue
    The two wires on the top of the pump are:
    Yellow (driver side)
    DK Blue (pass side)
    There are two black wires connected to ground, and the main red power lead.
    George
    • David H.
      • December 1, 1996
      • 241
      thank you so much George, I assume your wipers do work. David
        EVERYTHING George has works!
        • george romano
          LOL True! *NM*
