1961 Red Interior Paint - NCRS Discussion Boards
  • Stephen M. Moore
    Repainting the interior of my 1961 and I don't want to spend a lot of $ on spray cans. Can anyone give me an idea on the "mix" for the red lacquer paint and a lead on where to get it mixed. Thanks, Steve
  • Ed Jennings
    Re: 1961 Red Interior Paint
    One spray can is probably enough to do the interior, two at most. You'll probably spend more on getting lacquer mixed in small quantity. Even if you get a pint of base and flatten the clear, it will be more than a couple of spray cans. You can find the mixing formula on DuPont's website. Look up "Riverside Red". It is the same color and formula as "Roman Red"; only the name has changed.
    • Bill W.
      • March 1, 1980
      • 2000
      use roman red laqure with fast dry thinner & dont buff it .dupont #2931
      • Dennis A.
        • April 30, 1999
        • 1010
        Corvette Central has a Interior Lacquer (# 131075-*)*=paint code. in 12 0z. aerosol that is very good. I have used it for hardware interior parts I did not sray with the body. Be a little careful when the aerosol can gets a little low, for it will start to sputter, best to start a new can. also do not buff.
        • kenneth bingener NCRS#38563
          Re: 1961 Red Interior Paint/same ? but for 58
          Need the same info but for 58. What is the official name of the red for 58?
          Thanks, Ken
          • John M.
            • January 1, 1999
            • 1553
            It was called Signet Red.
              Thanks John! *NM*
