Bars Leaks - NCRS Discussion Boards
Bars Leaks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Bars Leaks
    i think it is in the heater core line to cut down on the noise of the water rushing thru the heater core. they had the same noise in the PU trucks because there was a TSB on it.
      • 15601
      Re: Bars Leaks *TL*
      Sorry Jim - mis-spellings are the bane of late-night postings. Try flow restriction.
      Not sure what its purpose is, but when it gets clogged there is a waterfall like sound that Clem describes below. The B-body internet scuttlebutt has it that the purpose is to slow down the flow of coolant through the heater core for increased heat transfer, but I am skeptical that is the reason.
      • Clem Z.
        • January 1, 2006
        • 9427
        #18
        Re: Bars Leaks
        i will check the GM tech website to see if the older TSB are still listed and try to find out the reason for the restriction.
        • Brian M.
          • February 1, 1997
          • 1839
          #19
          Re: Bars Leaks
          Aren't those B bodied cars reverse flow?
          • john pickens
            #20
            Re: Bars Leaks
            So overall it sounds like a slight coolant ooze at the waterneck gasket could safely and successfully fixed with Bars Leak instead of resetting the gasket?
              • 15601
              #21
              Re: Bars Leaks *TL*
              Yes, all the recent LT1s (B, D, F and Y bodies) are reverse coolant flow design.
              • Theodore K.
                • December 1, 1985
                • 214
                #22
                Re: Bars Leaks
                Clem,
                I think it was in a jar. It was a year or so ago. Really made me think twice about using again. I suspect vehicle did not recirculate it real well when I put it in. Maybe not hot enough.
                Ted
                BR>
