firewall toe heat shield color on 71 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    I removed my heat shields from the firewall toe area as they are covered with rust. Mine look like they were bare metal. I have seen replacement ones in catalogs calling for gray phosphate in color or "painted black". For 71 these are metal, and I have A/C. What color to the eye is gray phosphate? If these were painted then I will clean mine up and paint.
    Can you shed some light here.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 11644
    Re: firewall toe heat shield color on 71
    Gray phosphate is, ah, gray. It's sort of a flat rough gray texture that can easily be mistaken for dirt or corrosion. Mine had some rust on them, but I used a little muriatic acid to clean them after a thorough degreasing. They came out quite well. Othwerwise you may have to have them replated.
    Patrick
    • Ralph A.
      • May 31, 2002
      • 236
      Mine are rusted and will take a wire brush, or bead blast to remove. Can these be purchased NOS or reconditioned?
      Ralph
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
        • 43222
        Ralph-----
        I don't think that you'll find many NOS examples lying around, but the part numbers that you're looking for are GM #6263551, left side, and GM #6263554, right side (for A/C cars). Also, I don't know of anyone that sells reconditioned pieces; if you want reconditioned, then I'd just recommend reconditioning your own as Patrick describes. Reproductions are available, but I think that the reproductions are painted black. Some of the originals may have been, too, but all of the ones that I've seen are "gray phosphate".
        • Ralph A.
          • May 31, 2002
          • 236
          Thanks for the info. I will try a search for used OS. I have no plating eq.
          Ralph
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
            • 11644
            Check out Steve Gregori at www.brakeboosters.com if you want them replated.
            Patrick
            • Ralph A.
              • May 31, 2002
              • 236
              Thanks top all I found some in a junk yard
              I found a pair in a salvage yard in FL. they look like new original.
              Thanks to all that submitted helpful informaion.
              RA
              Ralph Adams
              NCRS: 38137 LA: 112
              Slidell, LA 70461
