Does anyone know where I can purchase a rear wire harness grommet that seals the wire harness and antenna in the rear of the car where it enters the passenger compartment. I can't seem to locate one in any of my catologues.
63 wire harness grommet
Re: 63 wire harness grommet
Paul------
The grommet of which you speak was GM #3784177. It was a 2 hole grommet with a one hole for the rear wiring harness and one hole for the antenna cable for cars so-equipped. This particular grommet was also used for some firewall applications. However, it was NEVER available in SERVICE from GM. For SERVICE, GM supplied only a 4 hole grommet of GM #3838273. That piece was discontinued in September, 1984.
While you could never get the 3784177 grommet from GM, you CAN get one from Dr. Rebuild. His part number is 1014649.In Appreciation of John Hinckley- Top
