frame paint - NCRS Discussion Boards
frame paint
+ More Options
Posts
  • Phil A.
    • January 1, 1998
    • 11
    frame paint
    Hello-
    Does anyone know the exact amount of flattening agent required to reproduce the semi-gloss black chassis paint for Regular (old fashion) IMRON. Our local Dupont agent claims he can only do flat black, even though he was given the formula number from our archives!! I know we have beat this subject to death but no where does the archives actually gives the percentages of the flattening agent needed.
    Thanks.
  • Donald L.
    • September 30, 1998
    • 461
    Re: frame paint
    Phil
    According to Rick Johnson,author of "Corvette Restoration Source Book 1953-1967"
    thinning the Imron 15% with Dupont 903-S Flattner should produce the correct sheen.
    • Wayne C.
      • November 1, 1978
      • 289
      Re: frame paint
      The formula I had was N8079U. My local paint supplier (handles DuPont and other brands) was able to get that formula.
      • Steve D.
        • February 1, 2002
        • 990
        Re: frame paint
        Any recommendations on a primer for the frame.? I will be starting with bare metal. (63 convertible)
        Steve
          Re: frame paint
          Steve -
          I did mine with DP-90 flattened about 20% - came out very nicely.
          • Wayne C.
            • November 1, 1978
            • 289
            Re: frame paint
            The primer Dupont recommended was Dupont 615S self-etching (used with 616S converter). Scrub the frame thoroughly with a quality metal cleaner/prep first (can't recall right now what I used, wasn't Dupont but it was a major brand... ask your paint supplier for a recommendation), then clean it again just to make sure, before you apply any primer.
