C2 carb - NCRS Discussion Boards
C2 carb
  • john pickens
    C2 carb
    I am trying to confirm the originality of my carb on my 65 roadster, 327/350. It has
    been rebuilt before I acquired it. The Holley website offers list numbers
    but their files cannot be opened or downloaded. Is anyone privy to info to
    ID a carb? It appears to be a 4150. Top number on air horn is 3849804.
    Third set of numbers is 2210, which I have read should represent a date code.
    Any thoughts? Thanks.
    • 43236
    Re: C2 carb
    John-----
    GM #3849804 is the carb used for 1964-65 Corvettes with L-76 or L-79 engines (1965). It is Holley list number 2818-A and it is a model 4150C. The "2210" is a date code which indicates that the carburetor was manufactured on the 221st day of 1970 or, possibly, even 1980 as this particular carburetor was available in GM SERVICE into the late 1980s. Obviously, it's a SERVICE carburetor, but it should be configured virtually identical to the original carburetor used on your car if yours is an L-76 or L-79.
      Re: C2 carb
      John -
      The configuration is correct, and the second line should read R-2818; the "2210" on the third line indicates that it's a service replacement, made in mid-August, 1970 (or 1980). The original OEM carb would have had a 3-digit date code.
      • john pickens
        Re: C2 carb
        I should also mention that the second line contains the code"L19T" followed
        by the 2818 code. The 2818 code is actually "2818-1" or "2818-I". Does this
        add any info? Thanks.
          Re: C2 carb
          John -
          The "-1" after the list number indicates a production change in the assembly since the original release. Assuming the configuration, finish, installation, metering block numbers, etc. are correct, you would only get a partial deduction (8 points or less) for the date code on the air horn.
          • Joe C.
            • August 31, 1999
            • 4598
            Re: C2 carb
            John:
            The second line of your carb. actually reads "LIST 2818-1", not "L19T 2818-1". This designation signifies a design change, and superseded the 1st design 2818A sometime between Holley production dates, June and September 1964. Your air horn stampings line 1 and 2 are correct, but the date code, as Joe and John have said, signifies a service replacement.
            The original primary metering body should have a "4094" stamp, without a "list" number. Secondary should read "4099"
            Joe.
              Re: C2 carb - Correction
              Oops! The second line stamp on the air horn won't have an "R" on it - it will say "List 2818-1"; the "R" is a Holley prefix for the model number, but it doesn't appear on the air horn.
