C2 Steering Damper - NCRS Discussion Boards
C2 Steering Damper
  • Ghere
    C2 Steering Damper
    I have a 63 convert., 340 HP, 4-spd. Did the L76 come with a steering damper? Can you help me?
  • Tom H.
    • September 30, 2002
    • 136
    Re: C2 Steering Damper
    no
      • 43234
      Tom and Ghere-----
      ......but, the steering relay rod will still have the extra holes for the steering dampner attachments. ALL 1963 Corvette steering relay rods were the same, regardless of whether a steering dampner was actually installed. So, don't be confused by the unused holes on the relay rod.
      • Myles Kukurudz
        I seem to recall that if you want to add one you might have issues with the oil pan ..regards Myles
          • 15692
          When I realized my '63 L-76 did not have a steering damper, I just figured
          the plant forgot to install it, but since the steering was fine
          I decided not to install one.
          Some years after that I finally came to realize that SHP/FI engines with the big oil pan did not have a steering damper because the long deep section of the oil pan precluded its installation without interference.
          This was also the primary reason that power steering was not available on SHP/FI engines with the big pan.
