Clutch chatter - NCRS Discussion Boards
Clutch chatter
  • Jim Johnson
    Clutch chatter
    I bought an unrestored original '57 a couple years ago. I love the car, but have
    a minor problem with clutch chatter only in 1st and reverse. I have records that show the disk, bearing and pressure plate were all replaced by a qualified shop before I purchased the car. There's no oil leaking onto the disk, that was the first thing I checked. There's no slip, and the new unit doesn't have enough miles to be worn out. Any ideas anyone?
    Re: Clutch chatter
    Jim -
    Most clutch chatter issues are caused by deteriorated or loose engine mounts or transmission mounts; I'd look there first, especially since the clutch is new. Also check out the clutch linkage (cross shaft and balls/sockets at each end for wear/looseness).
    • Jim Johnson
      Re: Clutch chatter
      John,
      Thanks for the help. The linkage also seems to be OK. I'll check the mounts. They're probably dry and brittle.
      • John D.
        • August 31, 2001
        • 280
        Re: Clutch chatter
        Jim:
        Was both the pilot bearing and throwout bearing replaced? A member of our chapter had a similar problem was the pilot bearing.
        Regards, John
        • Verle R.
          • March 1, 1989
          • 1163
          Re: Clutch chatter
          Clutch chatter can also be caused by a loose bearing on the input shaft in the transmission.
          I had a chatter problem in my 65. I replaced the disk and rebuilt the pressure plate and still had chatter. It was not until I replaced the disk and pressure plate that the problem was solved. The problem was the pressure plate.
          Verle
          • Roger Legge
            Re: Clutch chatter
            And a disc that doesn't slide smoothly on the input shaft splines. There's a whole bunch of things that can cause clutch chatter.
            Roger
            • John Walker
              Re: Clutch chatter
              I have also seen clutch chatter when the clutch is replaced and the flywheel was not surfaced.
              • Verle R.
                • March 1, 1989
                • 1163
                Re: Clutch chatter
                When I rebuilt my pressure plate I had the flywheel resurfaced and installed a new disk. Still had chatter. I don't know what the actual problem was but it went away when I bought a new pressure plate.
                Verle
