'58 wiper transmission cable lengths - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    I'm installing my transmissions and wiper motor. Driver's side is no problem. Passenger side, however, seems a little odd. The upper cable is ALWAYS longer than the lower cable. At park, it's 5.5" longer. At full up, it's 1.25" longer. Is this right? I can get the cables on the motor barrel, but the fit seems a little hinky (not to be confused with Hinckley, which would mean perfect!). Thanks for any help!
  • bob downs
    Re: push on the trans.
    have someone push in on the transmission where the wiper arm goes on. then while your under the dash pull on the cables at the same time. this will let then come out to max extension. to take up the slop just push on it again after you have the cables installed in the "CORRECT" order.
    • Ed Jennings
      Re: '58 wiper transmission cable lengths
      Mike, sounds like the cable may not be wound around the pulley properly. With the inner cable fully extended, I believe the measurement from the center of the shaft to the cable stops (held together) should be about 20-1/8". The only cable which extends is the inner one. Your outer cable may have slipped out of the grove and not be wound all the way around. Remember also that the cables on the right side (only) cross.
      • Ed Jennings
        Addendum
        Did I send you a copy of the instructions for installing transmissions? Thought I did, but maybe not.
        • Mike G.
          • April 30, 2001
          • 180
          Thanks guys
          Bob, I already knew about the clutch, just needed to see it the lengths were typical. Thanks anyway, though!
          Ed, I have the Restorer CD with the article. I'll e-mail my results when I get a chance. Oddly, this is the undamaged of the two transmissions, so I don't think the cable slipped a loop off, but we'll see!
