Ride Height - NCRS Discussion Boards
Ride Height
  • Henry Pozzuoli
    Ride Height
    What is the correct ride height for a 71 small block coupe. Mine seems very high compaired to most others I've seen. I replaced the trailing arms and bushings but not the leaf spring.
  • Dave S.
    • August 31, 1992
    • 2924
    Re: Ride Height
    The assembly manual should give you every possible dimension including the ride heights.
      Re: Ride Height
      Did you torque up the front trailing arm bushing bolts and the camber rod bushing bolts with the full weight of the car on its wheels, or with it up in the air? It makes a difference....
