71 M-22 LS-5 or LS-6? - NCRS Discussion Boards
  • Richard Hayes
    I have a question reguarding the M-22 in a 71 big block car. I have owned the car since 1981 but at that tme the engine had been replaced. I am currently getting ready to restore the car (for myself- do not plan on selling). I am in a quandry trying to figure out if it was origanally a LS-6 or not. The transmission numbers- tail- 3978764 Case- 3925661 Date code- 1B22BP Serial C11S115112 (VIN# 194671S115112) Bellhousing- 3858403
    After researching, it looks to be on one of the 130 or so M-22's that originally came w/ the car in 71.
    I have the tank sticker but it is unreadable in several critical areas. Date received- ?/04/06 Order #- OMS886(looks like?) zone- #08 dealer- #475
    Convert Nevada Silver Black Vinyl interior 1V400A8
    ***Turbo Jet 454 V8*** I can not read the option #. It looks like 1V???AA.
    I've read that the M-22 was the choice w/ the LS-6. The console shift plate must have been changed out before I bought the car due to the fake wood deluxe interior stating LS-5. The door panels are original and have the vinyl inserts.
    So is the car originally a LS-5 or the LS-6? The car has no power options-brakes/steering/windows/A/C.
    Any help figuring out what the car was originally- will be of great help!!!
    Richard
  • Ed Jennings
    Re: 71 M-22 LS-5 or LS-6?
    I owned a 71 LS5 when it was new and it did NOT have a M22. For whatever that's worth.
    • Michael S.
      • April 1, 1987
      • 364
      In 1976 I purchased a 71 LS-5 convertible that was loaded. It was numbers matching and yes, it did have an M-22. The VIN was on the transmission and it was listed on the tank sticker. This car was a very early build, late 600's in VIN.
      I owned this car for over ten years and sold in the mid-late 80's. It still had the original drivetrain.
      I may still have a copy of the tank sticker???
      • Jim T.
        • March 1, 1993
        • 5351
        Have you searched in the dash area for a copy of the build sheet. My 68 and 70 had build sheets in this area. Does the code on your transmission confirm the transmission in your 71 is a M22? All 4-speeds in your moded year had drain plugs.
        • Chas Kingston
          • Bernard S.
            • June 30, 1992
            • 56
            The tach redline should be 6500 if it was a LS6 and 5600 if a LS5
            • Richard Hayes
              Yes, from my understanding it is a M-22. I had it gone through 20 some odd years ago and the guy who worked on it said it was a M-22 w/ a 2.20 first gear. And it whined alot! The vin numbers match( last 5) and the C proceeds (A=M20 , B=M21 , C=M22 from what I have been told) The output yolk is almost as large in diameter as the driveshaft- which is also supossedly a tell tale sign of the M22. The bellhousing (# 3858403) is supposedly for the 10.4 dual disc.
              The interior is out of the car and there was no other build sheet to be found.
              Any help will be appreciated!!!
                • 15643
                M-22 does not have "straight" gears. They are helical (except reverse) as the other Muncies, but the gears have a lower helix angle, which gives them greater torque capacity and also makes them noisier.
                • Richard Hayes
                  If you are correct then my car is a LS-5. It starts getting orange at 5300 and red at 5600.
                  Thanks- I guess since the original motor is long gone - and not the really rare LS-6-I'm not quite as bummed!!! Although I have the owner's (that had the original motor swapped) name, address, DOB and SS# from 20+ years ago-just maybe I'll find it!
                    • 43203
                    Richard-----
                    A few things:
                    1) The "C" suffix code for M-22 trans was not part of the VIN derivative; it was part of the transmission production code (the other series of numbers stamped in a slightly larger font style). Your production code has an unusual series of characters; usually the "P" (the ID for the Muncie, IN transmission plant) is the first character in the series. In your case, it's last. In any event, the rest of the production code would indicate that the transmission was built for the 1971 (1) model year on February 22 (B22). The second "B" in the series indicates that it's an M-21.
                    2) Neither the LS-5 or LS-6 used the GM #3858403 bellhousing. Although all LS-6 with manual trans did use a 10" dual disc clutch, the flywheel was a 14", 168 tooth unit. The LS-5 used an 11" single disc clutch with a 14", 168 tooth flywheel (but, not the same flywheel as used for the dual disc set-up). So, both LS-5 and LS-6 used the GM #3899621 bellhousing designed for 14" flywheels. The only 1971 Corvettes which used the 3858403 bellhousing were the ZR-1s. However, the '403' bellhousing was used in MANY other Chevrolet applications over the years and is quite common. Someone retrofitted it to your car.
                    • Richard Hayes
                      hey Joe,
                      Thanks for the information. After finally figuring out what my car really was-'71 LS-5 w/ M-21 convertible. I am a little relieved realizing it's not that of a rarity, I'll feel more comfortable dropping in a ZZ502 and making it a driver.
                      • Norris W.
                        • December 1, 1982
                        • 683
                        Richard, one other comment that I didn't notice that anyone else mentioned. The later M21's had not only the lower drain plug but the big output shaft as well.
                          • 43203
                          Norris and Richard-----
                          Yes, ALL 1971-74 Muncie 4 speed transmissions used the 32 spline output and the same output yoke as 68-77 Corvettes with THM-400.
