C3/76 Foil Harison Sticker - NCRS Discussion Boards
  • Larry Gawron
    I need some help. I would like some info on the location and orientation of the foil Harison sticker that goes on the AC evaporator case. Can some one tell me exactly where to place it and which way it oriented? Thanks for the help in advance.
  • Tom R.
    • June 30, 1993
    • 4100
    Re: C3/76 Foil Harison Sticker
    Larry:
    I don't know if you've tracked this down but I'm basing this description on a 78 A/C evap case. The description is given with you standing over the passenger's side fender, peering over, into and at the case.
    The label is lengthwise and located two inches down from the screw that secures the two halves of the evap case. It's about 3/4 inch from seam where the two halves join. The orientation for the label is toward the engine; the way the label would be read. It's naturally backward.
    If you need a pic...let me know. I think I can get one to show the orientation.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
