pop rivets - NCRS Discussion Boards
pop rivets
  • Phil A.
    • April 30, 1982
    • 121
    pop rivets
    I was pop riveting the ends on my 1967 dash and the rivets would not pull all the way thru before separating. They would break about 1 inch from the ends of the stem, leaving a stub to cut off. Has anyone else had this problem? I bought these rivets from Long Island Corvette.
  • bob downs
    Re: pop rivets
    no rivet pulls all the way through. there designed to break close to the ball head but this doesn't happen all the time. you can take a punch and tap the stem in and let it go or tap the stem through and drill out and redo. you can try and make a cut mark where you want the rivet stem to break. this works for me.
    • george romano
      Re: pop rivets
      Be sure the grip range of the rivet is correct.
      George
