1963-82 Corvette Steering Relay Rods - NCRS Discussion Boards
    • 43240
    There was a thread recently on the board where an issue on 1965 relay rods was discussed. The thread went beyond just the 65 relay rod question, so I thought that I'd post a new thread. I've done a little more research on the subject and I think that I've got most of this figured out now. Herewith what I've found:
    As it turns out, the relay rods used for both small block and big block Corvettes during the 1963-68 period were the same. This is contrary to the information which I provided earlier and I was mistaken on this point. The 1963-68 manual steering relay rod for both small block and big block applications was GM #3831668. This relay rod is 3/4" OD and has provisions for the steering dampner, regardless of whether the steering dampner was actually installed.
    The 63-68 power steering relay rod for both small block and big block applications was GM #3822683. This is a 3/4" OD rod.
    For 1969, things changed. The PRODUCTION 1969 manual steering rod for both small block and big block applications was GM #3955512. This relay rod became the SERVICE relay rod for 63-68 BIG BLOCK Corvettes in February, 1969 when the GM #3831668 was discontinued. The GM #3955512 is a 7/8" OD rod and has no provisions for a steering shock absorber.
    Also for 1969, the power steering relay rod changed for PRODUCTION. The 69 rod was GM #3952707. This is a 7/8" OD relay rod. It became the SERVICE relay rod for ALL N-40 equipped 63-68 Corvettes when the GM #3822683 was discontinued in May, 1969.
    The "wrinkle" in all of this, and the thing that confused my recollection in my earlier post, is that there was another, SERVICE-only relay rod that was issued in 1969. This rod was a manual steering rod of GM #3955521. This rod replaced the GM #3831668 for SMALL BLOCK APPLICATIONS ONLY, although it could also be used on a big block. Although the GM information that I have on this rod is minimal and, I believe, partially incorrect, I think that this rod was a 7/8" OD manual steering relay rod which had provisions for the steering shock absorber used by 1963-68 Corvettes with small block and without the "6 quart" oil pan. This was a SERVICE-only rod since no 7/8" OD rod with provisions for the steering shock absorber was ever used in PRODUCTION. Since it was a SERVICE-only piece, apparently manufactured in very limited numbers, it carried a VERY high price when it was still available (which it no longer is).
    Why did GM change from the 3/4" OD rods to the 7/8" OD rods in 69+ AND replace the 63-68 rods at the same time for SERVICE with the 7/8" rods, INCLUDING MANUFACTURING A SPECIAL SERVICE-ONLY 7/8" OD manual steering rod for certain 63-68 Corvettes? You can bet it was not because the 3/4" rods worked just as good. Yes, indeed, you can be certain of that!
    Re: 1963-82 Corvette Steering Relay Rods
    Joe -
    The change from 3/4" to 7/8" may have been related to the steadily-increasing rim and tire widths (from 6" in '67, to 7" in '68, to 8" in '69) and fatter tire footprint, which would place higher stress on the relay rod; just a thought.
      • 43240
      John-----
      Yes, that could very well have been the basis for the reason. The front spindles, hub and bearing also changed for the 1969 model year. Also, I can understand why they would have used the 69 rods to SERVICE 63-68 applications since the 69 parts were generally interchangeable with the earlier and were an improved part.
      However, the part that makes me wonder about the reason for the increase in relay rod diameter has to do with the release of the SERVICE-only 7/8" OD rod for 63-68 small block applications. For those year cars, the tire width did not change, so, presumably, they could have just stayed with the original design rod and saved themselves the re-tooling cost for a low volume, SERVICE-only part. That's what makes me think that there is more to this story.
      • Chris D.
        • November 1, 2002
        • 198
        FWIW.
        I saw a reference to this in Van Valkenburgh's "Chrevrolet--Racing?", pages 201-202. Anecdote from the Thompson-Delorenzo racing effort. In 1967, relay rod buckled under heavy braking from 175 at Daytona. This lead to spin, a report back to Duntov, and eventually a heavier production part.
        Fact? Fiction? Hard to say, but the timing fits.
