Original Jet sizes for 69 Holley 3x2 - NCRS Discussion Boards
  • Howard Butler
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Original Jet sizes for 69 Holley 3x2
    Howard --- the original jets for the 4055-1 center carb were # 63's. The outboard carbs had metering plates (machined orifices) and no screw-in jets.
    • Dan M.
      • November 1, 2000
      • 48
      Howard,
      The stock setup for the front and rear carbs would have been a #76.The stock center carb would have been a #63 for a 4sp and a #61 for an auto.
      Dan
      Dan Morlang
      • Howard Butler
        Thanks for the info. It is much appreciated.
        Best,
        Howard
        38700
        • Craig S.
          • June 30, 1997
          • 2471
          Dan - I am confused by your commments on the #76 jets in the front and rear carbs since they contain metering plates versus metering blocks with chanageable jets....Craig
            1969 Shop Manual also shows #76 jets for the 2300 secondary carbs, which don't have jets - maybe they mean metering plates with #76-equivalent orifices? The Holley site just shows "N/S" or "N/R" for metering plates for the 3659 - no detail.
            • Clem Z.
              • January 1, 2006
              • 9427
              it is a #- 3 plate and the "jet hole" diameter is .076 dia
              • Craig S.
                • June 30, 1997
                • 2471
                Now that makes some sense!!...Craig
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  that was my trouble i always made sense but never enought dollars.
