C1 - broken wheel stud - NCRS Discussion Boards
  • Rick Krason
    What is the best way to remove a broken wheel stud from the axel plate? Broken flush to the plate, and doesn't seem to want to back out. WD-40 and a couple of light wacks isn't doing it...don't want to bend the axle plate out of true. I have a puller, but try as I might, can't seem to get it to fit over the plate in such a way as to make it work, besides, I have nothing to attach to !!!
    RICK
  • Roy Braatz
    Re: C1 - broken wheel stud
    You must back up the axle flang then useing a punch and hammer drive it out. That is the way I do it. Back up the flang again and hammer the new one in.
    • bob downs
      you didn't say if it is the front or rear. if it is the front you will need to pull the hub and put it in a press. if it is the rear put something behind it for support and beat it out.
