HELP!Wheel lock lost?Any suggestions? - NCRS Discussion Boards
  • vetter
    aNY INFO WOULD BE APPRECIATED.mY WIFE LOST THE WHEEL LOCK?should I drill it out?
    thanks guys..
  • John Rohe
    Re: HELP!Wheel lock lost?Any suggestions?
    "Vetter",
    If your wheel locks are "McGard" brand you (should have) registered with them when you bought them. They will be able to send you a new key for a nominal fee. If the above doesn't apply you might try a 12-point socket (just a little smaller than the outer lip of the locks) and a hammer.
    FYI, I've always used McGard wheel locks and always register with them - as well as order an extra key just in case.
    Good luck, John R. #31818
    • Paul E. Young
      I did't get the key with my car for the McGard locks. A local tire shop pounded on an impact socket just enough to catch and hit the socket with the impact . They came off suprizingly easy. Hope it helps.
