c-2 heater blower too slow: suggestions pleas - NCRS Discussion Boards
  • Tony DiGiorgio
    Hello all, I have a 67 that I plan on driving a lot. Problem is that the heater blower is way too slow, any of you upgraded the blower to make it really output well? sure there is a way to do this, with all the talent out there I knw someone has an idea ...
    As always, thanks in advance
    Tony Digiorgio
    800.837.0305 x111
    • 15680
    Re: c-2 heater blower too slow: suggestions pleas
    I never considered the heater blower to be "slow". It has three speeds.
    Do all three speeds work on your car?
    • Tony DiGiorgio
      Yes all three speeds work, slow, slower and slowest, need more volume any suggestions?
        • 15680
        Corvettes always had a reputation for having GREAT heaters. That's because they essentially used B-body cores and blower motors, but had considerably less interior volume to heat.
        You might want to run voltage checks at the blower motor power lead. At full speed it should show full system voltage. The lower speeds cut voltage by adding one or two series resistors that are mounted on the heater housing.
        If the voltage readings appear normal, you might just have a weak blower motor for some reason.
        • Ed Jennings
          Check the ground
          Could be a weak motor or low voltage, but a poor ground would affect all three speeds as well.
          • Gary cederman
            Re: Check the ground
            I agree with Duke that when they work right, the heaters are very good.
            If the voltages check out okay, you may want to check the motor itself to see how much drag it has due to bad bearings or brushes. I do not know of a good way to determine if it is good except that it should spin 'pretty' freely.
            • Roy Braatz
              I would run a wire directly from the battery hot side to the hearter motor RED WIRE to see how fast it runs with a full 12V, makeing sure the motor housing is grounded, that will make it run at top speed ,by passing the heater switch.
