C1 RADIUS RODS - NCRS Discussion Boards
C1 RADIUS RODS
  • Joe D.
    • April 30, 2002
    • 382
    C1 RADIUS RODS
    I INSTALLED MY REAR ON MY 1961.I FIRST INSTALLED THE SPRINGS. WHEN I WENT TO INSTALL THE RADIUS RODS, THE RIGHT SIDE WENT ON FINE. THE LEFT ONE IS ABOUT ONE INCH FROM LINING UP. THE MOUNT ON THE REAR FOR THE LEFT SIDE IS NOT EVEN WITH THE RIGHT SIDE, IT IS BACK FURTHER ON THE HOUSONG. IS THIS NORMAL? THAKS, JOE
  • bob downs
    Re: C1 RADIUS RODS
    well, was it lined up when you took it off?? if so did the housing seat on the bolt head on the leaf springs? loosen up the "u" bolts that hold the housing to the springs and see if that helps. are the radius rods the same length? has the mount been welded on? the radius bracket on the right side is the one that takes a beating not the left. my guess is you need to loosen up the housing and everything will fit.
