Lug nut Trivia Question - NCRS Discussion Boards
  • Everett Ogilvie
    The literature suggests that the long nuts for knock off adaptors are gold plated, and std lug nuts are zinc/silver plated.
    The standard lug nuts on my '69 are gold colored, and have 3 small triangular indentations on the outer surface, centered around the circumference of the nut.
    Could these be the originals for the '69? Would they also be the same for a '66?
    Were mid year std lug nuts silver? Were they stamped with the small indentations?
    thanks for any trivia!
    • 15623
    Re: Lug nut Trivia Question
    For what it is worth:
    My early 70 has silver plated lug nuts with the 3 indentations that you describe. There are some letters on them, but I would have to look to see what they are. As you know, we don't judge lug nuts, but every 1970-1972 I have seen was silver color. I would not expect a gold color on the lug nuts in my years.
    • Everett Ogilvie
      Thanks for the reply. I am going to assume that midyear lug nuts were also zinc/silver in color.
      Can anyone confirm if 66/67 lug nuts were silver in color, and if they had the three small indentations on the outer surface?
      thanks, Everett
      • Gene M.
        • April 1, 1985
        • 4232
        Yes, my 65, 67,matched Terry's
