C:3 ignition key removal - NCRS Discussion Boards
+ More Options
Posts
  • Gary Guthrie
    Would appreciate some procedural help on removal of the ignition key on a 69.
    Re: C:3 ignition key removal
    Gary -
    Manuals must be in reverse or automatics must be in Park in order to turn the ignition switch to the "Lock" position to remove the key. There is an adjustable "backdrive linkage" between the transmission and the steering column that operates this feature.
    • Jim T.
      • March 1, 1993
      • 5351
      What is it like when your 427/435HP turbo 400 shifts from first to second at WOT?
