C1 Master Cylnder - NCRS Discussion Boards
C1 Master Cylnder
  • Richard H.
    • March 1, 1985
    • 241
    C1 Master Cylnder
    Any recommended solvent (and duration) to put into master cylnder for cleaning purposes?
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Master Cylnder
    Richard,
    I usually glass bead The Master cylinders. They get a fair amount of rust on them and glass bead gets them as close to perfect as possible. The beads won't hurt the bore if it is not pitted, and a little 320 hone will polish it right back up. It is however, rare to find an original that does not need sleeving, but if it already has been sleeved then just hone it back smooth.
    Regards, John McGraw
    • Joe C.
      • August 31, 1999
      • 4598
      Richard:
      If you have removed all of your seals, etc., in prep for a rebuild, then I like lacquer thinner or, even better, acetone. The best way to achieve the desired effect is to agitate the immersion as much as possible. Both of these solvents are highly aggressive (with acetone being slightly more so), and will attack any rubber components in contact. They both evaporate very quickly (with acetone being slightly more volatile), but compressed air works best.
      Joe
      • Richard H.
        • March 1, 1985
        • 241
        Re: C1 Master Cylinder
        Joe
        Thanks for the information. How does one determine if the unit needs to be sleeved?
        Richard
        • John M.
          • January 1, 1999
          • 1553
          Richard,
          If the bore is pitted and can't be honed to a smooth finish then it needs to be sleeved. If you have yours sleeved, the general consensus is to go brass rather than stainless. It will wear in smooth sooner and be less likely to accelerate wear on the pistons.
          • Richard H.
            • March 1, 1985
            • 241
            Thanks John.
            • Mike Gleason
              I had Apple Hydraulics on Long Island redo my original MC for my 61. great job,
              quick, inexpensive. Brass is what I chose. For the little bit of money and time (up and back in 20 days) I would not even look at the bore. Apple is 800-882-7753 I spoke with Lazar. good luck.
              Mike Gleason
              NCRS #16176
              • Donald L.
                • September 30, 1998
                • 461
                Another good source is White Post Restoration.(www.whitepost.com)I live 50 miles from them and the turnaround by UPS was less than 72 hours. They have sleeved and rebuilt 2 for me. Cost $158.00 a pop which includes shipping.
                • Joe C.
                  • August 31, 1999
                  • 4598
                  Richard:
                  Sorry for the late reply--haven't been online in a couple. If your bore is heavily pitted/scored, then I agree with John, that sleeving will be necessary.
                  Joe
