Just wanted to confirm that the ignition coil in my 1966 L 72 engine (425 hp) is correctly hooked up. I have the white wire attached to the positive side of the coil and the black wire to the negative side. Is this correct? Also, what results if the wires are crossed? Thanks
Ignition Coil
