70 LS5 spark plugs......... - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    I pulled out the AC R43Ts and want to replace them with AC R45XLSs. The 45s are approximately a half longer than the 43s. I was wondering if there is a possiblity that the top of the piston will hit the plug.
    The motor is stock and has never been apart. It's 10.25:1 CR.
    Thanks, Chris
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 70 LS5 spark plugs.........
    no problem as there is plenty of room,but i do not think there is a 1/2" difference,only about 3/16". i have run XLS in 12.5:1 engines.
    • Dave S.
      • August 31, 1992
      • 2925
      Chris, What is the attraction to XLS plugs? Why not run a R45TS? Its a nice hot extended tip plug.
      • Clem Z.
        • January 1, 2006
        • 9427
        PS WARNING
        i am used to working with BB heads that use the 3/4" reach plugs and GM did change to TS but i thought it was later than 1970.
        • Dave S.
          • August 31, 1992
          • 2925
          Re: PS WARNING
          I used R45TS AC spark plugs in my 70 LS5 and it ran quite well. Although some do not agree, I am a believer in using AC plugs from the 70's with the 4 green rings.
