70 UA6 alarm hardware - NCRS Discussion Boards
  • Roberto L.
    • January 1, 1998
    • 523
    Hello, while working in the rear end, I found a rectagular plate (2 x 2.5 in) with an oblong hole (circular with two flats) plus a very thin bolt which mates the hole. I suppose this is the plate where the alarm lock screw in. This is an early 70.
    I'd like to know if these are original parts of the alarm system. At present my alarm system is disconected (lock missing) but alarm harness is OK.
    Thanks, Roberto, NCRS #30019, RMC
    Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
    • 43221
    Re: 70 UA6 alarm hardware
    Robert-----
    As far as I recall, the only plate similar to what you decribe which is associated with the alarm system in the rear portion of the car is the backing plate for the horn mounting bracket. The alarm relay was attached to a more-or-less "u" shaped bracket which was attached directly to the right side storage well with aluminum rivets. No backing plate was used for this bracket.
    • Roberto L.
      • January 1, 1998
      • 523
      Thanks Joe,
      the alarm horn bracket is different, I cleaned it and the horn and reattached to the left rear fender. I have the electrical components (relay and flasher in jack cmpt). I found the unknown bracket near the back hole, where the alarm lock should be, tied to the alarm harness by the previous owner.
      Thanks, Roberto
      • Juliet P.
        • June 30, 1999
        • 349
        Roberto - I e-mailed a photo to you of the backing plate from my UA6 alarm lock above the CORVETTE lettering in the rear. My lock is installed so I'm not quite sure what the shape of the opening is. Hope this helps. ~Juliet
        2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
        1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
        1965 Coupe (Greg's project No Flight)
        Gone but not forgotten:
        1987 Yellow Convertible 199k mi.
        2002 Yellow Convertible 100k mi.
        2007 Atomic Orange Coupe 140k mi. RIP flood 2015
        2007 Lemans Blue 6-Spd Coupe 34k mi.
        • Roberto L.
          • January 1, 1998
          • 523
          Thanks Juliet!! That's the famous plate. The flats in the hole are probably to index lock position. As the alarm lock is missing the previous owner just left the plate plus bolt hanging in the harness for future use.
