1975 Ignition coil or is it. - NCRS Discussion Boards
  • Trebor M #25911
    Joe, Thank you.
    The clutch has coil spring on front. The hub has 4 round holes that match the original pulley. The clutch cooling fins have slight curve towards the ends and a part of them do have a green expection mark. The clutch has "EATON" stamped in metal in front. The car is a early 69 car. I hope you can help. Thanks again.
    Trebor
    • 43260
    Re: Fan clutch info needed
    Trebor----
    Yes, with the additional information, it's quite easy. What you have is most likely a GM service clutch assembly. It could be GM #3916141 which has been around since 1968 and is still available or it could be one of several other similar service clutch assemblies which have now been discontinued. The 3916141 clutch is the absolute closest thing available new today with respect to the original configuration.
    • bigrtoys
      I have a 1975 with a traditional coil. I thought all 75's came with the "HEI" . Am I wrong? The engine matches. Any ideas I need educated.
