surface rust - NCRS Discussion Boards
surface rust
  • Ray Dattilo
    surface rust
    What's the best way to remove surface rust from unpainted parts such as clamps, brackets, etc. Thanks in advance.
  • Ted L.
    • May 31, 1999
    • 101
    Re: surface rust
    Ray,
    Naval Jelly if its very light. Let it sit in muratic acid overnight if its a little deeper or sandblast it if its deeper yet. In any case, you'll want to wash it and get it covered with something or it'll just rust again.
    Ted #32350
    • Bryan L.
      • June 30, 1998
      • 397
      Re: surface rust
      Ospho is also an excellent product and uses phosphoric acid, as does Naval Jelly. Ospho is around $8.00 for a quart bottle.
      BL
      • Juliet P.
        • June 30, 1999
        • 349
        Re: surface rust
        I used the bench grinder with the wire brush installed on it and locking vice grips to hold the smaller parts. Works great for outside edges, but you'll need to use one of the other techniques mentioned already for inside edges, or else a wire toothbrush. ~Juliet
        1970 Corvette Registry
        2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
        1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
        1965 Coupe (Greg's project No Flight)
        Gone but not forgotten:
        1987 Yellow Convertible 199k mi.
        2002 Yellow Convertible 100k mi.
        2007 Atomic Orange Coupe 140k mi. RIP flood 2015
        2007 Lemans Blue 6-Spd Coupe 34k mi.
        • Jon S.
          • November 1, 1992
          • 202
          Re: surface rust
          Ray,
          I prefer to glass bead those small parts and then hit them with lube 6. Rarely have I every had to go back and touch them up again. Of course, you should never use an oil to prevent anything from rusting if you intend to ever paint that part!
          Jon
          • Ray Dattilo
            Re: surface rust
            What is best to use to cover these parts after cleaning to help prevent rusting again without noticibly changing the finish? Thanks again.
            Ray
            • Jon S.
              • November 1, 1992
              • 202
              Re: surface rust
              Ray,
              All I used was lube 6 and I never had to go back. Lots of folks like to use a clear coating. But, I've found that to crack or turn yellow over time.
              Jon
              • Ray Dattilo
                Re: surface rust
                Jon,
                Can I get lube 6 at any auto parts store? Thanks,
                Ray
                • Craig S.
                  • June 30, 1997
                  • 2471
                  Re: surface rust
                  Ray - prelube 6 is avaialble from Quanta. See website below....I have not seen it in any stores....Craig
                  • Jon S.
                    • November 1, 1992
                    • 202
                    Re: surface rust
                    Ray,
                    I buy lube 6 by the quart from "Wild Bill" Davis. I prefer to wipe it on rather than spray it on. After a short period of time , I'll wipe the excess off. It's great stuff-industrial strength for sure!
                    His phone number: (508) 384-7373
                    e-mail: www.wildbillscorvette@att.net
                    Jon
