Sanding Grit - NCRS Discussion Boards
Sanding Grit
  • Ray C.
    • June 30, 2001
    • 1132
    Sanding Grit
    I am in the process of sanding the PPG polly primer on a 65 body restoration. I have just block sanded with 320 grit and will be spraying the red primer this weekend. What grit should I use to sand the primer before the lacquer top coats?
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Sanding Grit
    400 if by hand.
    • Ray C.
      • June 30, 2001
      • 1132
      Re: Sanding Grit
      Thanks!! Wayne
      Ray
      Ray Carney
