C2 SB Lower Fan Shroud Seal - NCRS Discussion Boards
  • Scott 38530
    For those of us who don't have access to a factory staple gun, how do you attach a new seal to the fan shroud?
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 SB Lower Fan Shroud Seal
    Drill a 1/16" hole through the original staple hole in the shroud and through the new seal. Push the staple through and use a pair of pliers to fold the staple over. Same procedure would be used for the mud flaps at the top of the A frames in you wheel openings.
