C3=engine info "73 - NCRS Discussion Boards
C3=engine info "73
  • Bob White
    C3=engine info "73
    This is my first time writing and I hope someone will take the time to help me.
    I need to check if my engine is an L82 as advertised and I don't know where to find out. I did get the following numbers from the block and I know its a 350;
    231508611
    K01 26 CKL
    Thanks in advance,
    Bob
    Re: C3=engine info "73
    Bob -
    The pad stamp says it's a 1973 350, built at McKinnon Industries (Canada) originally installed in a Canadian Pontiac built at the Oshawa, Ontario assembly plant.
    • jim34671
      Bob,
      The L82 engine code is listed as
      CLR,CLS,CLD,CLH..All these codes dependant on your particular application such as transmission type and emission equipment fitted.
      I can't seem to locate CLK for 1973.
      What you can also do is verify that the serial number code that you gave matches the last digits of your vehicle VIN as found on drivers windshield post plate.
      A true L82 "car" would be assigned a letter T in the fifth digit..
      ..ie 1Z37TS4.......
      • Bob White
        Thanks for the info.
        Looks like I've been had!
        I'll have to look for a repacement engine.
        Bob
        • Steve Lischynsky
          My 73, was completely built in St Louise, and shipped to canada. Why would there be canadian parts on it??
          Steve L
          73 coupe since new
          • Michael W.
            • April 1, 1997
            • 4290
            All '73 Corvettes have Canadian parts on them- as do previous and subsequent years. Similar to Canadian GM cars that have US parts on them.
            Not nearly as strange as the large % of Japanese parts that show up on new Harleys!
            • Michael W.
              • April 1, 1997
              • 4290
              Why look for a replacement?
              It won't be original either. The points difference in Flight judging between the block you have now and a 'close as possible' replacement make changing it a poor investment.
