can a block be 6 months older than - NCRS Discussion Boards
  • Larry Boden
    a 61. Buddies trying to build an engine for his 61 and the closest casting date he can find is a full 6 months before his assembly date. What is normal? I know on my 60 it was only 18 days before assebly date. I couldn't see anything in the judging guide. Any thoughts. Best Regards Larry
    • 43232
    Re: can a block be 6 months older than
    Larry-----
    The interval between your car's block casting date and your body build date is about the TYPICAL interval. However, I believe that both NCRS and NCCB allow a full 6 months "window" since, in exceptional situations, it's THEORETICALLY possible that such an interval could have occurred. This is VERY generous. However, I would guess that, given the generosity of the standard, that judges would be disinclined to stretch it further (e.g. 6 months + 3 days).
    • Loren L.
      • April 30, 1976
      • 4104
      The reason for the 6 month rule is to
      accomodate less-than-proliferate engine combinations; for instance, L88 motors MAY have been "batch-built" at Tonawanda and SOME might hang around St Louis for an extended time. If the 61 is NOT one of these, don't push the envelope beyond 6-8 weeks.
      • Craig S.
        • June 30, 1997
        • 2471
        Re: The reason for the 6 month rule is to
        My 1967 L79 KH car (PS,AC, and Calif A.I.R) was a May 11 car, with a April 29 body build date, and the engine was built on Feb 24. This is a rare combination unit and seems to fit the batch rule...it has been verified by Al Grenning and the pad is in his registry....Craig
